LED Moving head Lights
I recently had oen of my Chauvet Intemidator scanners decided to quit. Turns out the part that holds the light in it has gone bad. I am now cruseing ebay every now and then to see what types of moving head lights that are offered. I am pretty sure I do not want any of the 15W lights, and the 60W lights are a bit out of my price range right now. I was wondering if anyone had bought any LED moving head lights from someone on ebay? If so, how did you like them? Or, if anyone has another place that I could check out to get some new lights that won't cost me an arm and a leg.
- dmxlighting
- FreeStyler Version: beta
Re: LED Moving head Lights
Do you want moving head or moving mirror ?
If you are in the UK and want to buy NEW product then perhaps I can help. I have access to quite a few companies like Chauvet and I can do some good deals on theirs and other suppilers equipment.
Let me know what interests you and I'll find some prices for you.
Lee
Lee
thank you Lee, However I am in the USA. I am looking for moving head, not the moving mirror ones. The scanners I have now are moving mirror. Since you do work with Chauvet tho... mabye you can answer me this... Do they have a replacement part for the lamp base for an Intimodator 2.0 ? The lamp base in one of mine has gone bad and I need to replace it to get the light working again.
- dmxlighting
Chauvet UK are quite good for spares and in house repairs so I would guess that the US (being that Chauvet is American, although made in Asia) would have an equal or if not better service. I am a Chauvet dealer over here so they will do business direct with me. You may need to find a local dealer to get the parts you need but there is no harm in trying to go direct. Im sure they will help as much as possible.
All the best
Lee
All the best
Lee
