Chauvet Circus
jsquaredaudio
Chauvet Circus
Post by jsquaredaudio »
My first actual file, worked great at the show.
Has 42 preplanned programs, sound activated, program speed, and strobe.
I set the program I wanted to sound activation for the most part and it looked awesome
Circus.pff
(85.93 KiB) Downloaded 57 times
vdoggie
Re: Chauvet Circus
Post by vdoggie »
Can someone help me figure out how to adjust the sound active mode levels? I did exactly what the manual says but I can NEVER find the se.00~31 with ANY button in the correct order the manual says. I don' have a DMX and just want it in auto sound but with the microphone picking up the bass easier.. I don't like blasting people so they can't talk to each other.. this is in my basement..
if you want to check out my current little setup..
http://youtu.be/V3gEwpR18wg?hd=1
thanks!
Return to “Chauvet”
