Chauvet 6 Spot
jsquaredaudio
Chauvet 6 Spot
Post by jsquaredaudio »
This file has a ton of macros for color as well as color for single light use. You click on the color and then the 1 - 6 to turn that light that color.
Any questions just ask, but I used at a show and the single color, macro colors and the programs all worked great.
6 Spot.pff
(213.96 KiB) Downloaded 270 times
BuckinJB
Re: Chauvet 6 Spot
Post by BuckinJB »
Are you able to operate the 6-spot in the 3D viewer like you would live? Meaning, I cannot get the macros to operate in 3D.
Thanks.
scoot13
Re: Chauvet 6 Spot
Post by scoot13 »
Does this file work for everyone? I get an "Input Past End of File" error when I try to import it into freestyler. Is there another file for the 6 spot?
Re: Chauvet 6 Spot
Post by Jan_K »
Try this one.
This one opens correct on my PC.
Chauvet_6_Spot.pff
(212.96 KiB) Downloaded 171 times
It can also be found here viewtopic.php?f=23&t=4528
Return to “Chauvet”
