Coemar Samurai 1200 (incomplete)
BigBamg
Post by BigBamg »
I created the fixture for the coemar samurai 1200, but with some flaws:
- the colors are not perfectly match
- I have not entered the gobo shapes, but only progressive number
- There are two controls named shutter, but obviously only one is the shutter, and the other is the dimmer
- i haven't found the lamp on/off, and all others lamp function (reset....)
- fixture picture is not corresponding exactly
i named the fixture samurai 1200 inc.fxt, I hope to update it as soon as possible.
samurai 1200 inc.zip
fixture incomplete, read the post for details
(444 Bytes) Downloaded 28 times
gribouille
Re: Coemar Samurai 1200 (incomplete)
Post by gribouille »
Thanks!
I go to test!
I've modify the High End intellabeam fixture because the Intellabeam scan is a copy of the Coemar Samurai with 12 gobos and 12 colours. You confirm?
Post by Jan_K »
Hej Folks
Avolite has a personality driver for this fixture.
I am not hardcore reader for this file but there are other in the forum that can read this.
As I read it the Dimmer are on channle 8 and the values are
LAMP ON 0
LAMP OFF 128
MOTOR RESET 255
; The SAMURAI 1200 Personality for the Diamond II |
; History :- |
; Revision | Date | By | Description |
; 1.0 | 25-01-96 | Anwar | Created |
DEVICE=Samurai ; Device Name (upto 11 chars after '='
DEVICE23= ; 22 chars after '='
; extra information for softkey prompt lines 2&3
; a total of 22 chars, split into 2 lines of 11
; Device information
; __ Number of lines of DMX info.
; | __ Number of lines of wheel info
HSTART 1 8 1b05 150 110 ff 0 7 8 8
; | | | | | | | |__ Line number for flash button DMX info
; | | | | | | | from DMX definition (1..x)
; | | | | | | |__ Button release value
; | | | | | |__ Button ON value (ff means use swop/add fader)
; | | | | |__ The TILT arc in Degrees
; | | | |__ The Pan arc in degrees
; | | |__ Date in PC format (1b05==5/08/93)
; | |__ Number of DMX slots used
; |__ Patch direction (1-backward, 2 forward)
TEXTSTART ; Upto 21 lines of 28 characters (use the template below)
SAMURAI 1200 PERSONALITY ;
TEXTEND
; For the Attribute Dictionary refer to file 'dict.per'
; DMX information
; No unused lines allowed between keyword 'DSTART' and last DMX definition
DSTART ; DMX defintion
1 2 0 0 13 0 ; PAN
2 2 0 0 14 0 ; TILT
3 2 40 0 24 0 ; SHUTTER/STROBE
4 2 40 0 38 0 ; COLOR WHEEL
5 2 40 0 36 0 ; GOBO 1
6 2 0 0 15 0 ; IRIS
7 1 0 0 0 0 ; DIMMER
8 2 40 0 35 0 ; FUNCTION (LAMP OFF, MOTOR RESET, LAMP ON)
;| | | | | |__ Spare (always 0 for now)
;| | | | |__ Attribute name (See list above)
;| | | |__ Curve (0 means no curve otherwise curve number)
;| | |__ Flags (7=inverted, 6=instant, 5=16-bit)
;| |__ Channel type (1=HTP, 2=LTP, 0=Dummy(for 16-bit defines)
;|__ DMX offset (1..255, 0 means DIMMER will be patched seperately)
; WHEEL information
; No unused lines allowed between keyword 'WSTART' and last DMX definition
WSTART
8 ffff 6464 1 15 0 1 0 1 5 6 0 0 0 0 0 ; IRIS
8 ffff 0 1 35 0 2 0 1 7 8 0 0 0 0 0 ; RESET
8 ffff 0 1 38 0 3 0 1 3 4 0 0 0 0 0 ; COLOR WHEEL
8 ffff 0 1 36 0 4 0 1 4 5 0 0 0 0 0 ; GOBO 1
8 ffff 8000 3 13 1 5 0 1 0 1 0 0 0 0 0 ; PAN
8 ffff 8000 3 14 1 6 0 1 1 2 0 0 0 0 0 ; TILT
8 ffff 8080 1 24 0 7 0 1 2 3 0 0 0 0 0 ; SHUTTER/STROBE
8 ffff 8080 4 0 0 8 0 1 6 7 0 0 0 0 0 ; DIMMER
;| | | | | | | | | | | | | | | |__ List of Table channels as
;| | | | | | | | | | |_______________ line numbers from DMX def.
;| | | | | | | | | | ff or 0 means unused channel
;| | | | | | | | | |__ DMX line pertainnig to this wheel (-1)
;| | | | | | | | |__ Number of chanels under control (Table width)
;| | | | | | | |__ Table type (Attribute number) 0 means NOT a table
;| | | | | | |__ Wheel number (1..8 on bank1, 9..16 on bank2 et cetera);| | | | | |__ 0 for 8 bits, 1 for 16 bits
;| | | | |__ Attribute name from above list (0..MAX)
;| | | |__ Wheel type (1-offset, 2-Table, 3-Pan/Tile, 4-Dimmer)
;| | |__ Default value (left shifted as necessary)
;| |__ AND mask, where more than wheel controls same DMX slot
;|__ Wheel multiplication =16-(bits used)
; eg. for 8 bit channels it is 8, for 12 bit channels it is 4
; TABLES
; Each Table is enclosed by the keywords "TSTART" and "*** TEND ***"
; The legend is 16 chars long
; The correct number of values must be supplied (8-bits) with spaces in
; between
; FUNCTION TABLE
; __ Table width (upto 6 allowed)
; | __ Type of Table from attribute list
TSTART 1 35
LAMP ON 0
LAMP OFF 128
MOTOR RESET 255
*** TEND ***
; GOBO TABLE
TSTART 2 11
GOBO1 NONE 12 0
GOBO1 1 38 0
GOBO1 2 64 0
GOBO1 3 89 0
GOBO1 4 114 0
GOBO1 5 140 0
GOBO1 SLOW 153 0
GOBO1 MED. 191 0
GOBO1 FAST 255 0
GOBO2 NONE 0 12
GOBO2 1 0 38
GOBO2 2 0 64
GOBO2 3 0 89
GOBO2 4 0 114
GOBO2 5 0 140
GOBO2 SLOW 0 153
GOBO2 MED. 0 191
GOBO2 FAST 0 255
*** TEND ***
