Hi, I've read about a pre-heat function which is where a filament lamp wont drop below 5%-10% of its power to help preserve life of the lamp. Is there a function to do this in freestyler? Where I can set individual light fixtures minimal values meaning the light doesnt drop below that level. I tried creating a fixture myself but it didnt work. I know I can run a sequence doing that and then run another sequence on top of it if that makes sense but I was wondering if there was another way.
Cheers Stephen
Pre-heat Function
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Pre-heat Function
set the minimum value for your fixtures using the pull out sliders, then right click and set as minimum
