6 spot Topic is solved
jsquaredaudio
6 spot
Post by jsquaredaudio »
Anyone have any luck building the chauvet 6 spot fixture. I have seen the 4 bar made as separate pars within 1 fixture but I do not know how to handle this....
any ideas
Here is the specs
ViewType = VIEW_TYPE_COLOR_CHANGER
ViewPower = VIEW_POWER_LED30W
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 16
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
Channel 1 through 6 = pod
no_function,0,10 [5]
red,11,45 [28]
green,46,80 [63]
blue,81,115 [98]
yellow,116,150 [133]
magenta,151,185 [168]
cyan,186,220 [203]
white,221,255 [238]
Channel 7 = strobe
no_function,0,9 [4]
strobe,10,255 [132]
Channel 8 = control
seperate_pod_control,0,10 [5]
auto 1 18
auto 2 65
auto 3 106
auto 4 131
auto 5 156
auto 6 175
auto 7 202
auto 8 225
audio,240,255 [247]
jsquaredaudio
Re: 6 spot
I guess I should have put what I do not understand.
there are 6 individual lights with 8 different settings just for color and there is only 1,23, gobo wheel and 1,2 color wheel which only gets 5 of the lights going.
I did not see how I could make a macro to give me all the settings with out making 48 macros....is that what it takes?
Also, then does the strobe still work if I end of having to make all those macros?
Re: 6 spot
Yes that sound the most logic way to me.
Just create 8 macros for Each Light. You can also do it with the Formula you can use with Fixture creator
look at: http://www.freestylersupport.com/wiki/f ... plications
This page Shows what your seaching for.
jsquaredaudio
Re: 6 spot
I used Channel one only and then used the ch0x=ch01 and I got all the colors....only issue I am having is with sound activation, but that is with all my lights, I am sure I am missing something
Re: 6 spot
yes i think you miss something.
but i never use sound to light or pre programmend Chases. so i can not help you with this.
jsquaredaudio
Re: 6 spot
Just me being lazy....I am new but figuring out the fixture creator very fast. I know this is not the most powerful way to use FS, but I first I will do manual switching until I get good at programming.
I will be making a lot of Macros today for this light though
Re: 6 spot
it's realy good to Start with the Fixture Creator this way you Learn how your Fixture Works and all the Feature that the light haves.
And aftre that its the LONG learning progress of Programming your own Sequences.
I also learned allot of Real profesional lighting gay's.
and they learnt me how to use the Submasters(Playback faders, Because i used the Avolight Pearl desk to learn it), and the idea behind everything.
But its realy easy if you understand it.
But the Cuelist buttons and Submaster are 2 totaly Differnt ways of programming ;)
jsquaredaudio
Re: 6 spot
marcsikma
Re: 6 spot
Post by marcsikma »
i am working on this right now--
can't figure it out--
anyway you can share your thoughts with me?
please email: marcsikma@gmail.com
jsquaredaudio
Re: 6 spot
I will post the fixture file tonight...used it at a show, works well
jsquaredaudio
Re: 6 spot
File posted in the chauvet fixture forum
