ultradmx
jsquaredaudio
ultradmx
Post by jsquaredaudio »
There is no setting for ultradmx by dmxking, what to I use???
dmxlighting
FreeStyler Version: beta
Re: ultradmx
Post by dmxlighting »
Ive not heard of this one before. Best to try out various different ones and see if you can get a match.
mixinstein
FreeStyler Version: 3.4.6
Re: ultradmx
Post by mixinstein »
jsquaredaudio wrote:There is no setting for ultradmx by dmxking, what to I use???
On the DMXKing.com website is says to select the "Enttec USB Pro" as your DMX device if support for the DMXking.com interface is not available. They state 100% compatibility with the "Enttec USB Pro".
I like the fact it comes in a 3 pin XLR so I do not have to use a 5 pin to 3 pin adapter. Please let me know how this works as I was just looking at buying one of these "ultraDMX" by DMXKing.com.
Re: ultradmx
I have been reading this topic and it seems a Easy anwers to me ,But now i see you it looks alot more Complex.. :D
But DMXKing and Enttec pro use both the same Chip a FTDI chip you can also find the Latest Firmware from the FTDI Website. and there are more devices that uses the same Chip ;)
But the UltraDMX and ultraDMxPro uses the same Drivers.
And with the latest update 3.4.6 the developer added two New interfaces , UltraDMXPRO and Madrix.
So i would try the UltraDMXPRO interface, but i do not have a DMXking device so can not try it my self.
But i'm going to test it with my enttec pro, look if it work.. :D
Re: ultradmx
Oke i tried it and mine Enttec pro Worded on "DMXking USB DMX512-A" and on "EUROLITE USB-DMX512 Pro" and also offcourse with the Enttec pro.
Only UltraDMXpro did not work on the enttec pro.
/Spirit
mixinstein
Re: ultradmx
Set the interface to "Enttec USB Pro"... I use that for my UltraDMX interface... works great. On the DMXKing.com website is says to select the "Enttec USB Pro" as your DMX device if support for the DMXking.com interface is not available. They state 100% compatibility with the "Enttec USB Pro".
jpk
FreeStyler Version: 3.5.2
Twitter: twitter.com/dmxking
Re: ultradmx
Post by jpk »
Spirit wrote:Oke i tried it and mine Enttec pro Worded on "DMXking USB DMX512-A" and on "EUROLITE USB-DMX512 Pro" and also offcourse with the Enttec pro.
/Spirit
The ultraDMX Pro interface supports 2 universe output (although we're still waiting for FS to be updated) and you should select the driver when using it. It also works with the Enttec Pro driver but falls back to basic mode with only 1 universe output.
http://DMXking.com USB DMX and ArtNet interfaces.
Return to “DMX Interfaces”
