ADJ Quad Phase
Lion
ADJ Quad Phase
Post by Lion »
I've seen some people ask for a Quad Phase fixture ... not finding one, I made one with everything set up (colors, rotation, etc).
Be aware that the system Blackout function doesn't work right with the Quad Phase as when you set Sound Active mode, it pretty much ignores EVERYTHING until you unset it. In fact, if you set up a color gobo and a strobe value, then put it in Sound Active when you bring it out of Sound Active that color gobo and strobe will return.
Quad Phase.pff
American DJ - Quad Phase fixture file
(31.82 KiB) Downloaded 416 times
TB sound & light
Re: ADJ Quad Phase
Post by TB sound & light »
Good work, thank you! :fs:
maybe i will change the color buttons in "real colors", because with the "rgbw" version you have to think about which button creates which color and sometimes its difficult to click on the right one :D
best regards from Germany
Timo
gareth
FreeStyler Version: 3
Re: ADJ Quad Phase
Post by gareth »
many thanks
sebzic
FreeStyler Version: 3.4
Re: ADJ Quad Phase
Post by sebzic »
thanks a lot, I've changed the color. it's easier, but, good job ! thanks a lot
Re: ADJ Quad Phase
Post by Jan_K »
If you have an updated profile then please upload it. ;)
JayShoe
Re: ADJ Quad Phase
Post by JayShoe »
I just took a moment to make this fixture have the colored boxes outlined so that they are easier to locate on the gobo selection panel.
Quad Phase.pff
(31.82 KiB) Downloaded 190 times
pjp
FreeStyler Version: 3.4.8
Re: ADJ Quad Phase
Post by pjp »
Thank you, JayShoe! Works good.
djjeckyll
Re: ADJ Quad Phase
Post by djjeckyll »
Thanks everyone for the great work! This helped a ton!
Return to “American DJ”
