Chauvet Circus Topic is solved
jsquaredaudio
Chauvet Circus
I am new to this so I am going to try and make the Chauvet Circus fixture, I will upload tonight as I do not see it anywhere on the forums.
Can someone check my work if possible?
jsquaredaudio
Re: Chauvet Circus
Here is the info on this light
ViewType = VIEW_TYPE_NOTHING
ViewPower = VIEW_POWER_LED30W
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 16
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
Channel = color_macro
Program 1,1,5
Program 2,6,11
Program 3,12,17
Program 4,18,23
Program 5,24,29
Program 6,30,35
Program 7,36,41
Program 8,42,47
Program 9,48,53
Program 10,54,59
Program 11,60,65
Program 12,66,71
Program 13,72,77
Program 14,78,83
Program 15,84,89
Program 16,90,95
Program 17,96,101
Program 18,102,107
Program 19,108,113
Program 20,114,119
Program 21,120,125
Program 22,126,131
Program 23,132,137
Program 24,138,143
Program 25,144,149
Program 26,150,155
Program 27,156,161
Program 28,162,167
Program 29,168,173
Program 30,174,179
Program 31,180,185
Program 32,186,191
Program 33,192,197
Program 34,198,203
Program 35,204,209
Program 36,210,215
Program 37,216,221
Program 38,222,227
Program 39,228,233
Program 40,234,239
Program 41,240,245
Program 42,246,251
Sound,252,255
Channel = speed_control
Speed,0,251 sound sinsitivity,252,255
Channel = strobe_effect
strobe,0,255
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 16
Program 1,1,5
Program 2,6,11
Program 3,12,17
Program 4,18,23
Program 5,24,29
Program 6,30,35
Program 7,36,41
Program 8,42,47
Program 9,48,53
Program 10,54,59
Program 11,60,65
Program 12,66,71
Program 13,72,77
Program 14,78,83
Program 15,84,89
Program 16,90,95
Program 17,96,101
Program 18,102,107
Program 19,108,113
Program 20,114,119
Program 21,120,125
Program 22,126,131
Program 23,132,137
Program 24,138,143
Program 25,144,149
Program 26,150,155
Program 27,156,161
Program 28,162,167
Program 29,168,173
Program 30,174,179
Program 31,180,185
Program 32,186,191
Program 33,192,197
Program 34,198,203
Program 35,204,209
Program 36,210,215
Program 37,216,221
Program 38,222,227
Program 39,228,233
Program 40,234,239
Program 41,240,245
Program 42,246,251
Sound,252,255
strobe,0,255
jsquaredaudio
Re: Chauvet Circus
So, the programs are cool and alll, but I am assuming they are considered macros in FS. Does that mean I need to figure out each pattern and make a little gif to match with each?
I will do that but can someone tell me if that is the case.
Doubt I will get anything posted tonight but I am working on, all just so new to me
- Spirit
- FreeStyler Version: 3.5.9
Re: Chauvet Circus
Like with inbuild programmes i just Use the Icons 1, 2, 3, 4, 5, 6, 7, 8.
But in the end it just how you like to have it.
- Spirit
Re: Chauvet Circus
You can use Macros or the Third gobowheel.
But its not a Big deal.
jsquaredaudio
Re: Chauvet Circus
Why not the 1st gobo wheel. I am just trying to understand how to build fixture files
- Spirit
Re: Chauvet Circus
read this page, and all the links you see
http://www.freestylersupport.com/wiki/fixture_creator
thats because , i have never seen a Fixture with 3 Gobo wheels.
So the third Gobowheel is mostly Used for other commen functions.
and the Macros is a Jocker Function, it can be used for realy everything.
jsquaredaudio
Re: Chauvet Circus
First try at this, anyone want to take a loook and see if it makes sense
Gobo2 is Speed of program
Gobo3 is built in programs
and then there is a strobe pattern.
For some reason I could not export as a pff so I attached a zip file with all the files I used
Circus files.zip- (13.96 KiB) Downloaded 44 times
- Spirit
Re: Chauvet Circus
Ahh yes i used it and i see a Fault, Sorry but i also forgot this.
But the Gobo Window does not Open. but that comes because there is No Gobo1 Channel.
So if you Change Gobo wheel 2 To Gobo wheel 1 then that problem will be solved.
Only the bad this is You need to Redo all the Values again.
You can also Change Gobowheel 3 to 1
And the Lamp panel wil not Open and thats caused because there is no Shutter ch Or Intensity ch.
and to solve this i would recommend to fill in the Chutter ch. to 3 and Open = 255 (Fast Strobe) Closed = 0 (Shutter off)
But Shutter closed is also the Blackout feature with in Freestyler, so that will not work. And it will stops The Strobo.
/Spirit
/Spirit
jsquaredaudio
Re: Chauvet Circus
I will redo tonight and re-upload...I am also going to take picture of each of the 42 programs so it is easier to tell what each is
jsquaredaudio
Re: Chauvet Circus
Finished this file with pictures for the in-built program. Anyone with a Circus let me know if it works for you.
I get my DMX to usb tonight so I will try it out as well
My first attempt at building a fixture but I think I did it right
Circus.pff- (85.93 KiB) Downloaded 72 times
jsquaredaudio
Re: Chauvet Circus
It works for the most part, but sound activated program does not work....any ideas for me
I even tried to activate the sound mode but it didnt do anything
- Spirit
Re: Chauvet Circus
oke and you also turn on the Program Speed? ch.2
