Hi Guys long time reader first time poster!
I've recently purchased a kam hexaflower 1, I've been reading the fixture creator tutorial and I'm completely stuck. Its a 6 lens RGB light with 9 channels.
What's the best way to create a fixture? would it be a separate fixture for each lens then a master or one fixture with some macros?
Any help would be greatly appreciated, or if anyone has this fixture already created and wouldn't mind sharing that would be great.
http://www.kam.co.uk/media/file/product ... manual.pdf
Cheers
Matt
Kam Hexaflower 1 Topic is solved
- FreeStyler Version: Beta
Re: Kam Hexaflower 1
Hej Matt
If the lens only change colors and don't change intensity in the range that are defined then I think I would do it as one fixture with some macros for color control and then use the show in function.
But it requires that the light is constant in example the red range 11 to 45.
Pidea
- FreeStyler Version: 3.5.2
- I Use FreeStyler for: Band
It's a bit of an old thread this but in case anyone is still looking for the Hexaflower fixture file, it's here:
viewtopic.php?f=23&t=5017
