Cue problems Topic is solved
Torbenc
Cue problems
Post by Torbenc »
Hi
I have some problems when using cues.
If i run a cue where I use par cans and shift to eg. a program with my moving light, the par cans that was on when pressing another cue, will stay on. I is the same problem with moving light... If I select a new cue, the color, and gobos from the last cue will stay on in the new cue.
If I have a strobe on, it will also not turn of in the new cue.
I have tried all release options I can find - The problem seems to be, that it dosen't turn of the "old" dmx values from cue to cue.
Re: Cue problems
Yes, thats because you did not record on the Cue that you like to turn off the Old values.
So i think you make your sequence's Transparent if you change this to Static, your problem will be solved.
Torbenc
Re: Cue problems
Post by Torbenc »
Thank you, that was much better :)
