I posted this request in the wrong area and was redirected here. I tried to create the file for the Stage Light 300 but unsuccessfully. I have posted for help but no responses. I want to use this fixture to explain to my 7th grade math class in a way that would engage them about the coordinate plane. Any help is appreciated. I am not a lighting person but thought I could use this to help students learn. I have attached the Stage Light 300 manual to help. Thank You for your consideration, Collin
The channel assignments will be:
1-off
2-on
3-on
4-on
5-on
6-on
7-on
8-on
9-on
10-off
11-off
12-off
Collin
Fixture File for Clay Paky Stage Light 300 Topic is solved
collin
StageLight300_Manual_Rev.1.pdf- (822.05 KiB) Downloaded 150 times
- Spirit
- FreeStyler Version: 3.5.9
Re: Fixture File for Clay Paky Stage Light 300
Oke take a look at this fixture.
I'm not sure if the Color and Gobo are set correct, because i do not know if they are stepped or Proportional.
collin
Thank you very much for your help! I really appreciate it. Collin
- Spirit
Can you also Verfy if this fixture file work good?
collin
It seems to work great, I will need to work with it more although all of the functions are working. I am new to Freestyler so I worked through changing colors, gobos, pan, tilt, strope, light intensity, all worked great. Thank you!
