hi all
having a bit of a problem with CUE buttons...
i'll press one cue button (say 4 LED cans will be red at full intensity) and everything will be ok. however, when i press another CUE button (2 moving heads, white facing forward), the LED cans will still be on red when they should be off
i've gone into the editor and made sure the LED cans are 'off' and not 'snap' or anything like that and at 0 intensity yet the actual lights are still on.
any suggestions as to what's going wrong?
thanks in advance
CUE button problems Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: CUE button problems
go to here :
http://www.freestylersupport.com/wiki/p ... k_sequence
Go to "Other Cue Functions / Options"
Now search for "Restore DMX values when sequence stopped" that Icon if you Enable it you see a Blue arrow end that will turn the light back off.
you also need to save it again so that option will only be on the cue you like to have it.
If i'm not wrong
If i'm not wrong
kristof
Options "OFF" ,"SNAP" and "FADE" are to control the behavior of the light when changing values, meaning:drunkenmind wrote:hi all
... made sure the LED cans are 'off' and not 'snap' or anything like that and at 0 intensity yet the actual lights are still on.
OFF: the channel set value will be ignored (the light won't switch off nor set the channel value to zero)
SNAP: channel value will snap (will ignore fade time)
FADE: channel value wil fade according to fade time (i.e. slowly dimming)
Set the LEDs to "SNAP" or "FADE" and report if you have any troubles.
- Kings
- Commited FS Forum helper
CUE button problems
Sounds like LTP (latest takes precedence) behavior to me. FS responds to the last commands given. Unfortunately any sequences already running are partially overridden so if it's a LED par it will just 'hang' on the last color. If its a scanner, the same happens and the mirror stops moving. I would love it if FS had the ability to run more than one cue button at a time.
