3D Viewer not working!!
- FreeStyler Version: 3.4.4
Hello, I am having trouble getting my 3D viewer to work. I put my lights and everything in, and I am not able to get the icon to light up so I can press it.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: 3D Viewer not working!!
Possibly you do not have the sunlite installed, did you select it suring the instalation?
No, I don't believe I did check it. I will have to uninstall and then re-install?
