3.4.4 doesn't start! [SOLVED] Topic is solved
Locked
phatbooker
Post by phatbooker »
I cant get the software to open! Ive read many other threads of the same issues, but see absolutely no resolution. And no, a de-install and re-install doesnt resolve the issue. How am I to use this software if I cannot get it to start? Out of curiosity, I loaded the same "setup" install file onto a windows XP machine and it starts just fine?
Can I get a link to download a previous version that actually works?!
SO frustated !!! :evil:
FIXED: http://www.freestylersupport.com/fsforu ... 986#p16369 - Matt
Android Dev (Moderator)
FreeStyler Version: BETA
Re: 3.4.4 doesnt start !!! Why is there no fix for this ?
Post by Mattotone »
Theres no fix as one hasnt been found yet. Try the front of the forum for a stable or previous release
yes thats the problem mattotone, the devolper also added version 3.4.4 as the Last Stable version :? But it's not!
and i think it can not take any long now before the next release comes.
http://www.freestylersupport.com/bugs/view.php?id=300
Here you see it's fixed asap. but i also can not understand why this takes so long. it's allready more then a Month.
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
Seriously, 1 month isn't that long and considering the developer does this for free, I think you need to cut a little slack buddy. What OS are you running it on?
Yo Buddy the last couple of mounths I helped the devolper solved over 100bugs so i now what i'm saying.
and I also Do it for Free.... or i get a Nice stable version and New features!
and it runs perfect with me Tested OS: Winxp 32bit and Win7 64bit.
buttza
Post by buttza »
I don't doubt it bro. :)
Is there still an issue with it? Mine works fine. I do remember having an issues when 2 versions were installed to separate folders. Other than that it has been fine for me after I uninstalled and reinstalled with only the 3.4.4 version on 3 different machines. :)
Could be regkey issues when installing updates if there has been any mods done etc.
Post by Mattotone »
Got this reply from Raph today!
Hi Matthew
Normally it should be this file, should be placed in the FS directory.
I'm busy preparing a new release but serious bugs in the submasters prevent it from being released.
I hope to release it this week.
Raph
global_colors.rar
(217 Bytes) Downloaded 255 times
phatbooker
downloaded this file, Unzipped it and added it to the freestyler directory. IT WORKS !
thanks for the update. Ill add any input next time I attempt to use the software.
wesley2004
Re: 3.4.4 doesnt start !!! Why is there no fix for this ? SO
Post by wesley2004 »
i wish this solved my problem but it;s not.
Still doesn't start with dmx dongle inside laptop!
buttza
Post by buttza »
What do you mean?
'Still Doesn't Start with DMX Dongle in laptop?'
You have a laptop with a built in DMX dongle?
it probably doesn't work as he has rammed his dmx dongle into his CD drawer etc lol ;)
Locked
