I´ve got some questions about the extrernal control of freestyler.
Is there the possibility to control/dimm/flash single parcans with an external controller for example Korg Nano Control? I thougt about 8-16 Channels.
When yes, i´m also able to dim/flash the pars if there is running a Cue (eg. the Movingheads)?
How i´ve got to programme the scenes/cues for the ohter devices (Heads, LEDs) to ensure this function?
So I don´t have to install two DMX-Lines, one for Freestyler (Movingheads, LED-Effects etc.) and one for my DMX-PAR Controller.
Thank you for supporting.
Markus
External Controllboard for Freestyler
- FreeStyler Version: 3.5.2
- Spirit
- FreeStyler Version: 3.5.9
Re: External Controllboard for Freestyler
Yes this is posible.
You can use MIDI to DMX to assaigne a DMX channel to a Fader on the Midi controler.
and you can make up to 24 Midi to dmx channels
Yes you can also use it During Playback, it will be maked as a Manual override and to Release it use "Release all"
Also the Korg nano should work with freestyler, I would also recomend to look at the BCF2000 from beheringer.
i hoped this helped you.
Oh yes,
it is the answer I looked for.
The Behringer BCF 2000 with Motorfaders sounds and looks very interesting.
Let´s bye and try it.
Thank´s a lot.
Thank´s a lot.
