what is the most stable os to run freestyler
- FreeStyler Version: 3.3.2
im wondering what is the most stable way to run freestyler 3.3.2 on my everyday computer laptop (thinking about creating new partition and second os) my laptop is not a bomb, its a acer celeron M 2gb of ram 1.6ghz intel cpu. its running fine without lagging just wondering whats the most stable setup
- Spirit
- FreeStyler Version: 3.5.9
Re: what is the most stable os to run freestyler
there is only one OS you can use, thats Windows
But offcourse your asking for Windows XP, Vista or Win7
it should run just good on all the OS's.
I have used:
Compaq laptop 15", 1Ghz + 512mbram on Xp 32bit, and it runs realy sweet.
acer laptop 10", 2x1.3GhZ celeron + 1Gbram on XP 32bit, also runs very sweet.
packer bell laptop 11", 2x1.5Ghz Intel Pentium + 2Gbram on Win7 64bit, also runs very sweet.
and my own made pc: 4x3.56 Ghz AMD athlon + 4Gbram on win7 64Bit, Run realy realy sweet and fast.
and in the past i also used old Socket "386" with 128mbram. with win98.
and i also used windows vista, never had any problems with one of the OS's. everything should work the same.
I have used:
