Getting Fixture Profile From 3D Easy to FreeStyler Topic is solved
jdycus
I need a fixture profile for FreeStyler which is not in the Freestyler database, but is in 3D Easy database. Is there any way to get that information over form 3D Easy to FreeStyler? Tanks
- Spirit
- FreeStyler Version: 3.5.9
Re: Getting Fixture Profile From 3D Easy to FreeStyler
no not possible, because its made by 2 differnt devolpers.
but if you say which fixture you mean i can help you
- Spirit
Ahhhh realy nice i have seen these LED lights 2 weeks a go, and they REALY lookt nice.
But i did not know which type it was until now
But you can have 5 Differnt modes which one would you like to have TOUR, ARC1, ARC1+D, ARC1+S Or HSV.
http://www.chauvetlighting.com/products ... _UM-WO.pdf
jdycus
4 Channel. Thanks for your help. We (our church praise band) are really pleased with these lights. Just need to get some type of control that is relatively simple for our volunteers to be able to use. Do you think FreeStyler is the way to go, or is there something better/simpler?
- Spirit
Here i uploaden the file can you test it.
Also if you like to know more about freestyler and Fixture creator look at this page:
http://www.freestylersupport.com/wiki you can also find the link on the top of this page as "The Freestyler Wiki"
/Spirit
/Spirit
Colorado 1 Tri 4Ch.pff- (25.62 KiB) Downloaded 54 times
jdycus
Worked great! Thank you so much for your expertise and help.
joedigitaltv
spirit, could i get the 11 channel version from you?:)
tks
tom
tks
tom
