Global color function with not dmx lamp Topic is solved
arn:o)
Post by arn:o) »
I'm a beginner with DMX light (Enttec Usb box), but I have a lot of not DMX Lamp.
So to don't but every mylight in the trash in the first time, I have buy somme Swith et Dimmer Pack.
There is a new fonction about "GLOBAL COLORS" in Frrestyler.
My request is about the possibility to affect to not-DMX fixture (PAR36, 64 light) the color of them.
And have the capabilty to use the simple color light materials in the global color function.
Thanks.
Re: Global color function with not dmx lamp
i don't understand way you would like to have a Global color on a Static light.
because the Global color id is only made for colorwheels. and usefull if there is a Colorwheel.
arn:o)
Post by arn:o) »
The aim's of the Global color is made to turn all the colorwheels on the same color. One the result is to have the same color in the room or on the light.
I try to explain in english, that if you can add the color (Red, Green, Blue, Yellow, Violet, Pink, White, Multicolor) of static light when you add the fixture in FS, after you can chose a global color and FS turn off (or reduce) the wrong color. And perharps it can light on the good color or boost the static light for the chosen color.
You understand better ?
Return to “Ideas and Remarks”
