DMX400 Problem: One fixture not reacting to it
Locked
Goofy
Post by Goofy »
Hi :mrgreen:
I'm an otherwise happy freestyler (2.96h) user and so far, it has never let me down to a point i couldn't solve... But now I'm in a bit of a situation... I'm trying to run 4 Robe MSZoom 250XT with the DMX400, and as far as i know, i've set everthing up as it should be, but the first fixture in the line doesn't respond to the intensity changes of the DMX400... :roll:.
I've checked the DMX output, and the problem seems to be within freestyler, as the output of the fixture's dimmer channel is fixed to whatever i set it to manually and not changing at all... All three of the other heads are working superbly with DMX400... Very confusing...
I'm thinking that it might be some override i'm missing to reset, but i cannot seem to find it...
Hope you guys can help :)
Goofy
PS: :fs:
Goofy
Re: DMX400 Problem: One fixture not reacting to it
Post by Goofy »
Well... Problem has been solved :). I don't know why, but changing the adress of them all helped. Problem only occured when first fixture's DMX adress was 1-16... Very mysterious :P
See ya :mrgreen:
apprenti bidouille
Post by apprenti bidouille »
i've got exactly the same problem...
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
[bugreporting][/bugreporting]
lol @ mattotone... straight to the point!
Post by Mattotone »
V tired this morning 4 shifts in two days lol
:fs:
rick_v
Post by rick_v »
I have the same problem, the "channel 1-16" solution did not work. Someone else an other solution?
djmaq
Post by djmaq »
@Goofy: Have you reported the bug in the "Freestyler reprot bug system" or have I to do so?
Post by Mattotone »
Bug reported.
Topic now locked to prevent oher users reporting the same problem, once confirmed by Raph will be added to the known bug report.
kind regards
Matt
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Post by matt »
Yes this is a Known Issue with the DMX 400. Channel 1 is not Accessible.
Matt Hankosky
flickr.com/photos/mattxhank
Locked
