Matrics RGBW, how to do with the white color ? Topic is solved
arn:o)
Post by arn:o) »
I have the Nicols GALACTIS Led lgiht effect, it's LED matrix with 256 LEDS (16x16). It's possible to command with 256 channels, one by led. There is 4 color's led RGB and White.
I have an probleme to create the fixtures (and with Ledtrix plugin too), because is just RGB segment without the white.
So can you help me, to use my light effect ?
The Notice :
http://www.google.fr/url?sa=t&source=we ... YA&cad=rja
