Stairville RoboHead X-3 LED
dorrimoldi
Post by dorrimoldi »
Hello,
I have a RoboHead X-3 LED by Stairville, which has 3 axis, but i cannot find the fixtures for it in the library.
It uses uses 16 DMX channels. Please have a look here: http://images.thomann.de/pics/prod/253248_manual.pdf (or see the attachment)
Where can I find the fixture for this Sairville RoboHead X-3 LED for the library? I've tried using "Fixture Creator", but I do not know where I can set the Pan1/2/Tilt speed channel and above all how to assign the Pan2 using the FreeStyler FixtureCreator in order to properly create/control this fixture in FS.
Can anyone help me? It will be extremely appreciated.
Thanks a lot in advance and have a nice day! :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :) :)
253248_manual.pdf
(609.11 KiB) Downloaded 27 times
Re: Stairville RoboHead X-3 LED
Take a look at this tutorial and it solves all your problems.
http://www.freestylersupport.com/wiki/f ... d_fixtures
It's the Freestyler wiki and you can find alot more Info about freestyler here.
But if you stil have problems you can ask.
/Spirit
dorrimoldi
WOW!!!! You are the man!!! Thank you. It seems to be the solution... I will learn from that page and I will try to create the fixture.
Thank you SO much!!!!!
Return to “Stairville”
