3D viewing Topic is solved
steve 96
3D viewing
Post by steve 96 »
I want to know where i can get a virtual stage setup that i can control with freestyler without any dmx adapters or anything. it needs to be accurate so i can program on it then take those programmings to a real stage. can anybody help? (im new, ok :D )
Re: 3D viewing
Whats your problem.
/Spirit
Re: 3D viewing
Freestyler already comes with this kind of software and its called Magic 3D Easy View
wardomon
Re: 3D viewing
Post by wardomon »
Magic 3D is great for designing light shows. You will, however, still have to tweak the positions. The correlation between the virtual stage in Magic 3D and the real world is tenuous at best.
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: 3D viewing
Post by buttza »
If you are having issues with setting up Sunlite Magic Easy View 3D Below are some of the threads that might help.
Issue with SLMEV not working:
http://freestylersupport.com/fsforum/vi ... =56&t=6387
Freestyler X2 not communicating with SLMEV:
http://freestylersupport.com/fsforum/vi ... =56&t=6060
