Here is the Blizzard Lighting The Puck RGBAW LED Par can fixture file (ssl2) for Magic 3D Easy View
The ssl2 file only has Mode 1 for 12 ch operation.
channels 7-12 (color snap, snap speed, color fade, fade speed and sound active) are included but they are setup as 'free'. These channels will not work with FreeStyler and/or Magic 3D Easy View.
Blizzard Lighting The Puck RGBAW LED Par Can Topic is solved
djnyce
The Puck RGBAW.ssl2- (6.23 KiB) Downloaded 204 times
