Good day Can someone help me as I enter the fuxtures for the LED BAR 300? I would like to operate in 09CH mode. RGB LED BAR
CH1 = red1
CH2 = Green1
CH3 = Blue 1
CH4 = Red 2
CH5 = Green 2
CH6 = Blue 2
CH7 = Red 3
CH8 = Green 3
CH9 = Blue 3
Since I can only enter two colors.
Thank you for your help
Involight LED BAR 300 Topic is solved
docMario
Re: Involight LED BAR 300
Hi, I don't know if this still is an issue...
In my eyes, the best way to program those kind of fixtures with multiple RGB elements is to split them up, i.e. make a 3-channel fixture for each RGB segment. Then subsequently patch three of your virtual fixtures to form your physical fixture.
Now let's say you have a Fixture with the following DMX profile:
CH1-3 Master Dimmer, Function, Macros, Strobe
CH4-6 RGB 1, CH7-9 RGB 2 etc.
Then create two different virtual fixtures: one for the "control channels", one for the RGB segments.
best regards, mario
best regards, mario
