Freestyler Sequence in Magic 3D EasyView
djnyce
FreeStyler Version: 3.5.1
Twitter: http://www.twitter.com/djnyce
Post by djnyce »
thanks to the forum and the wiki i know how to control lights, add fixtures create sequences and use submasters.
i have also learned how to crate stages in Easy View.
I wanted to know if it is possible to see your Freestyler sequence being run in Easy View?
If not, without actually plugging in all of the lights to the usb interface is there a way to visually see what your sequence looks like?
Usual Suspects Entertainment
We make the crowd move
http://www.djnyce.com
Re: Freestyler Sequence in Magic 3D EasyView
YES offcourse that way there is a 3d View ;)
You can also find the anwer on the Wiki :D
Between "HELP! i never used freestyler,i were do i start?".
and "troubleshooting"
djnyce
Post by djnyce »
my problem was "Light doesn't react to the dmx out from freestyler." i did have virtual interface selected but the problem still occurred. after re-installing freestyler and selecting virtual interface my sequences are now running in easy magic.
thanks.
