Blizzard Lighting The Puck RGBAW Topic is solved
djnyce
Post by djnyce »
I did not see a request for this. If someone has this or can make one i would be much obliged.
Re: Blizzard Lighting The Puck RGBAW
Hello, djnyce
Creating your own fixture isnt that hard.
we encourge people to learn how the Fixture creator works.
Because the next you need a Fixture file and there is no time to wait on someone on the forum, you can create your own fixture file.
And jan_k made alot of tutorial to ceate your fixture:
http://www.freestylersupport.com/wiki/fixture_creator
and if you still have problems you can aks them.
djnyce
Post by djnyce »
thanks. i will give it a try and report back here.
djnyce
Post by djnyce »
i was able to make the fixture but could only get strobe, red, green blue, amber and white to work.
how do i handle other functions such as dimmer, color snap and color fade?
1 Dimmer
2 Strobe (0-15 off, 16-255 strobeslow <-> fast)
3 Red Intensity
4 Green Intensity
5 Blue Intensity
6 Amber Intensity
7 White Intensity
8 Color Snap
9 Snap Speed (0-15 off, 16-255 Snap Slow <--> Fast)
10 Color Fade
11 Fade Speed (0-15 off, 16-255 Snap Slow <--> Fast)
12 Sound Active (0-127 off, 128-255 Sound Active)
1. Dimmer is the same as "Intensity"
9. and 10. these funtions ared necesary with freestyler, you need to play with these value's and look what works the best with freestyler.
But freestyler Just send a bunch of Dmx value's to the fixture. 0,1,2,3,4,5,6,7,8,9, and on... With Fade.
and if you use snap i goes 0,50,220,170 and on.
