another midi trigger non starter... Topic is solved
daveymuso
Post by daveymuso »
Hi
I know this has been discussed before, but none of the other threads are helping me...
My setup...
Sonar 5 -> loopBe internal midi -> Freestyler.
Sonar is outputing th channel one of the loopBe
FS midi input is set to LoopBe
I have a note C4 playing from sonar at 127 velocity
I put FS into start to listen for midi -- it captures successfully the note (48) against the toggle blackout command.
When I hit stop, then save, and then play the note it does not trigger the blackout
I have tried numerous different commands & notes
I have tried changing the option 'note on -note off' in the setup page
Re: another midi trigger non starter...
daveymuso wrote:When I hit stop, then save, and then play the note it does not trigger the blackout
sound thats your problem, if you hit stop then it will stop the External midi control.
it needs to stay on Start.
Start = Midi controlls ON
Edit = Listen to the midi note's you send and puts it on a External command
Stop = Midi controlls Off
daveymuso
Post by daveymuso »
ah brilliant, thanks spirit.
I was thinking i was capturing -- hence start capture - stop capture.
all working --- just got to suss the rest out now :)
k__x
FreeStyler Version: 3.3.4
Post by k__x »
hi!
i have loopbe to, and im with the same problem, im using REAPER to send the MIDI to loopbe, and in freestyler MIDI setup, in START -> EDIT, it read the NOTE (50) and Velocity (127) to "Toogle Blackout" for example, and i selected in OPTIONS only the NOT ON NOTE OFF
it only work and do the "toogle BLACKOUT" if i keep the Freestyler SETUP windows opened...i dont understand why...if i select in OPTION -> Convert FLASH to toogle BUTTONS it shows me the real MIDI input but dont work, dont make the tootle blackout...
if i "save", it dont work =(
i dont know why, can you help me please?
