FREESTYLER 3.3 2 wont start!!! HELP Topic is solved
Coolscott7
OK this is my 2nd attempt at using freestyler. I spent about 5 hours making fixtures with the fixture creator. I had 12 fixture or so all addressed, etc. Tonight I went to start Freestyler, and it wont start! It did this to me about 6 months ago, so I reinstalled a couple weeks ago, losing all of my previous work. NOW it wont start AGAIN, and I dont want to lose my new fixtures, locations, etc......Why wont it start? How can I reinstall without losing my hard work? I am using windows vista. Thanks
- Spirit
- FreeStyler Version: 3.5.9
Re: FREESTYLER 3.3 2 wont start!!! HELP
yes of course you can save everything.
the fixture you can Export it to a .pff file.
all your sequences and Cue's are located in de freestyler directory.
but maby for the next time if freestyler works make a Backup file of your location.
but your problems sound trange because 3.3.2 is the latest stable version, i ahve never had any problems starting it up.
