Easy View 3D - black and white only
jimivaughnking
- FreeStyler Version: 3.0.1
Hopefully I am missing something simple. I'm trying to use the visualizer, got my fixtures working but the beams are not showing colors, only white beams. I have several LED fixtures and all of them are white only regardless of color settings. Freestyler is showing the color setting correctly and the Visualizer DMX Universe is showing the correct values but the display is not showing it. Any ideas?
- Spirit
- FreeStyler Version: 3.5.9
Re: Easy View 3D - black and white only
This can be caused, becuase of the fixture file you use in 3d view, maby the setting aren't correct?
which led par are you trying?
