Velleman k8062 Problem Topic is solved
CustomSound
Post by CustomSound »
Hi there.
I'm using FreeStyler for over 2 years , thank's for those behind, this, only with enttec open dmx and everything worked fine , sometimes i had some crashes but hey i didn't mind.
Now I have a Velleman k8062.
In test mode de console works fine, with de dmx dmx player suplied by velleman the same : works.
The chanels from 0-512 with all values from 0-255.
The problem is : the dmx chanels over 100 are not working with FS.
I decresead the output refresh rate but stil the same problem.
The cables aren't the problem , i double checked .
I used only one fixture with different adresses :
- FS maxim chanel is 96 after that no adress work
- with velleman software any adress works fine
So i think that the problem is with FS driver for the dmx console.
Any thoughts for fixing the problems.
The velleman software has an option to select the maxim chanels 8,16,64,96,255,512 i think , could it be that freestyler doesn;t know how much chanells to alocate?
CustomSound
Re: Velleman k8062 Problem
Solved
In conclusion : choose you console wisly
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
CustomSound wrote:Solved
By this do you mean 'Don't use a Vellerman device' ?
I would agree with that. They are rubbish. Enttec Open or Pro is the way to go!
(other quite good devices are available ;) )
Return to “DMX Interfaces”
