I have 2 futurescans 3 CED, and I got yesterday, 2 contests SCN800.
As well as I have a party on this saturday night, I will have no time at all to build sequences, so I tried with random values.
I have questions about random values :
- I can set tilt/pan limits in the triggering window, but how can I set limits for gobos and colors/stutter ?
- How can I synchronize 2 same fixtures in react more ? I mean one reacts to sound with random values, and the second acts synchronized to the first.
- Is there a way to "capture" random values to transform them as sequences ? Like a recording.
Thanks a lot for your help !
Couin
Questions about random values Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Questions about random values
The random function is very basic, which I not likely to be used by many. Building a couple of sequences can be done very quickly. Make one for movement containing 10 or so positions. One for colour one step for each colour, and one for gobo one step for each gobo. And then set each to play in random order. This will give you the effect you want.
