The New Global id Feature
Oke for the poeple how like to know how it works, i all ready made some fixture you can try.
http://www.freestylersupport.com/fsforu ... =69&t=3126
http://www.freestylersupport.com/fsforu ... =69&t=3677
http://www.freestylersupport.com/fsforu ... =64&t=3302
http://www.freestylersupport.com/fsforu ... =61&t=3137
These fixtures support the global id Feature.
and some extra features: you can also use led pars, with fixtures that supports the global color id.
this only works with single RGB/CMY fixtures, RGB sigments doesn't support a Global color id
