JB-Lighting VaryLED 384 Topic is solved
Fetenjung
Post by Fetenjung »
I have a file figures posted for the above given MH. Unfortunately I'm not sure if I've done everything correctly. Can you please once you look at the thing and possibly improve. For safety, I have also attached the original channel occupancy times.
Thank you for your help
Hallo zusammen,
ich habe ein figuren datei für den oben genanten MH geschrieben. leider bin ich mir nicht sicher, ob ich alles richtig gemacht habe. Könnt Ihr euch das ding bitte mal anschauen und eventuell verbessern. Zur Sicherheit habe ich auch noch mal die Original kanalbelegung beigefügt.
Danke für Eure Hilfe
VaryLED384.zip
(1.41 MiB) Downloaded 90 times
Re: JB-Lighting VaryLED 384
Hello,
Looks great.
only there are 2 little things.
thets the Strobe ch it should be Ch6 and not 5.
the Lamp channel ch7, your fixture doest have a Lamp ON/OFF channels.
And it's realy good you typed it in english but if your going to send a manual, it would be nice to have the english one and not the german one... ;)
Fetenjung
Post by Fetenjung »
Sorry, I had the instructions in German only. Thanks for the two notes. But I have a problem with the pan and tilt control. When I look at the 3D Easy View, then I get the movements are not implemented cleanly. Can this have anything to do with the 8-bit and 16 bit controllers.
