Installing error Topic is solved
karlmcd
Installing error
Post by karlmcd »
Hey, im a lover of fs, have used it on my laptop while djing and in night clubs for ages now with no problems,
untill now,
i tryed loading it onto a pc (running windows xp) but everytime i go to install it it tells me that the file is corrupt.....
is there something im doing wrong or is there a version for xp??
Cheers
Karl
Re: Installing error
i have re- installed 3.4 on win7 and it seems to run fine.
1) Did you allready tried to redownload and try again?
2) did you also tried it on a other pc with xp?
and if nothing work on that pc and other pc work perfect, try to reinstall Xp.
karlmcd
Post by karlmcd »
iv tryed reinstall it on my laptop (win7) but i havent got the accese to an other comp on xp
heard people saying that if you use firefox to dl it it should work??
will try this later when i get into the venue...
still strange, i donwloaded it 2 weeks ago on xp IE8 and it worked perfect.
but you can also try firefox.
You need to clear your internet caches, then instead of downloading it to xxxx location pick a new location as browsers will assume you have already download the file and use the one you already have.... if that doesnt work you need to search your pc and remove any of the download files in any location and start again.... the reason your getting that issue is its the same file always being loaded the corrupted one!!
yes sound logic.
because i needed to reinstall win xp on a other hdd. so mine cach was empty.
