Slow Load Time
mobilegreg
Just started using FS
FreeStyler Version: 3.0.1
Slow Load Time
Post by mobilegreg »
I have a strange issue. I am running FS 3.4 on a WinXP system with a Enttec DMX USB Pro controller and when I first run FS, it takes forever to load. Once the software is loaded, it runs just fine. I had the same trouble with the current release as well as with the latest beta release. Any ideas? All other programs seem to load just fine even though it is an older system.
Re: Slow Load Time
what are the specs from the pc and which version do you mean, 3.4 and ? (3.3.2).
you can find here the recommended specs : http://www.freestylersupport.com/wiki/h ... quirements
but these are old specs, maby you allready need a little bit faster pc.
it also depant if you use touchscreen interface or midi. or both at the same time.
Re: Slow Load Time
or if your pc gets slow I always wipe it and start again :)
mobilegreg
Re: Slow Load Time
The computer is a P4 2.8GHz, 512MB running win XP SP 3.
