Insert Picture in Creator Topic is solved
LJ Lodikiller
Hi, I will make a new fixture for my Stairville RGB Theatre Spot. But I can't insert my picture from the spot in the creator. What must I do? How big and which format (GIF, JPEG, BMP) must the picture have?
- djSupport
Re: Insert Picture in Creator
gif or BMP not Jpg best think to do is open another file and see teh dimensions on that I'd open up the parcan (silver one) as thats big so its like the limit... then if you save it as a gif or bmp it will work
