Hello.
I have a dimmer that uses 2 channels per device to control the intensity of LED panels. It uses 16 bits to describe the level of the output.
I am unable to create this in Freestyler. The only available options for 16 bits are pan and tilt. Any tips?
I'm using the latest 3.4.
16 bit dimmer? Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: 16 bit dimmer?
No freestyler doesn't support a 16bit intensity/dimmer channel
if you open the fixture creator then you go to the Channel description tab and there you can call the channel 16Bit Dimmer.
stanelie
Re: 16 bit dimmer?
So...
The channel would be correctly labeled, but it would not be used to do a precise fade for example...
I guess I have to look for some other software that is capable of using 16 bits channels.
Thanks!
Thanks!
- Spirit
Re: 16 bit dimmer?
you can still use that channel only you need to do everything with the mouse.
it depants on how the 16bit channel work, never seen a Fixture with a 16bit dimmer can you post a link?
- Spirit
Re: 16 bit dimmer?
no you can not do a high resolution fade with the 8bit and 16bit
