Hello,
i'm pretty new to Freestyler, but I've allready got my fixtures created and have them working in FS manually.
Now i'm trying to build some sequences, but this isn't exactly going the way i hoped it would be.
Let me explain my problem :
I have a setup with some movingheads and ledpars.
First I create a scene with the moving heads (selecting colors, gobo, position) then I open the "create sequence window" and I click on the "+" button to add this step to the sequence.
When I now try to create another scene (for example select another color or position), then the movingheads don't react anymore, it seems like the output is blocked. When I close the "create sequence window", then I can control my movingheads again.
Any clue about what i'm doing wrong ? I guess it must be something stupid, but I really don't see it
grtz,
Patrick
Problems when trying to create sequence
- Spirit
- FreeStyler Version: 3.5.9
Re: Problems when trying to create sequence
hello, daxmon
Your new so i recoomend to take alook at the freestyler wiki, http://www.freestylersupport.com/wiki/
but your have some troubles with creating a sequence so take a look at here, http://www.freestylersupport.com/wiki/sequence_editor
maby this will help
also if you open the Cue/submaster window and you now open the Create sequence window you will be in OFFLINE mode and if the Sequence editor say's it's on Offline mode it will not send any output.
maby this will help
Thank you spirit !
It was the cue-window that put the Sequence editor in Offline mode.
I was following the tutorial in the wiki, but i had overseen the cue-window.
thx,
Patrick
thx,
Patrick
