Hello,
You can do that with midi to dmx.
24 is the maximum
/ spirit
More MIDI options?
- Spirit
- FreeStyler Version: 3.5.9
Re: More MIDI options?
- Spirit
hello again also look at this http://www.freestylersupport.com/wiki/e ... re_control
these are all external controls.
for parcans i recommend to use Midi to Dmx
With the mid to dmx you don't need to select a fixture.
and for the Ledpar i recommend to use the Cyaan/red, Magenta/green, yellow,Blue channel
with rgb channels you need to select a fixture, for external control you can use the Groups or Prev./next Fixture.
allot of Fixture controls.
