slider sharing
speedymany2k
slider sharing
Post by speedymany2k »
Hi guys.
Slightly new with freestyler.
I have recently managed to use freestyler with my splabs usb-dmx interface with is an enntec open dmx.
Now, i have 2 X qtxlight slimline 64 parcan and 2x prolight krypton equniox flashers.
I put the cans to sddress 1 and the kryptons to address 10. When i use the sliders or the macro buttons on the kryptons, the cans are responding in the same way.
Would this be because i am using a long cable as i know i should be using a short cable.
Thanks.
speedymany2k
Re: slider sharing
Could someone reply to this if they know what could be the problem?
Could it be that i need a terminator on the last DMX out port?
wardomon
Re: slider sharing
Post by wardomon »
Cable length is only an issue at extreme lengths, +400 feet. A terminator should always be used and are easy to make. Remember that European and American DMX assignments differ by one.
I've got an NSI DDS-5600 4-ch dimmer set up at DMX send address 93-96 in Freestyler. It's fixture number 15 along the line. The DIP switches 1,2,3,5 are on, so that in binary is 23. I spent the better part of an hour powering down, changing DIPs and powering up to get this working. You may need to do the same thing.
biggus
Re: slider sharing
Post by biggus »
@ speedymany2k --- hi all my first post. What do you think to the splabs dmx interface? im in the market for a usb to dmx and I'm thining of buying one
