DMX400 Fixture
MuschelInBlau
FreeStyler Version: 2.96h
DMX400 Fixture
Post by MuschelInBlau »
I have problems with the DMX 400. I have already read the manual 10 times but i can't find the failure.
I can't add a PAR56 in the DMX400 (Rightclick Use in DMX400) Freestyler says: This fixture hasn't got an intensity channel an is not an RGB fixture.
So please help me :(
:fs:
regards Jan
Inverted Reality
LJ
FreeStyler Version: 3.0.1
Re: DMX400 Fixture
Post by Inverted Reality »
Hi Jan,
it does look like the PAR56s don't have intensity channels, and there isn't the option to give them one when you open them in the fixture creator. As a quick fix you could swap the PAR56s in freestyler with PAR64s as they work.
MuschelInBlau
Re: DMX400 Fixture
with par64 is it the same problem :(
MuschelInBlau
Re: DMX400 Fixture
Ok the problem is fixed i tried to edit the fixture in the editor i gave the Description "Intensity" and it works! ;)
thx 4 help ;)
DMX DAVE
FreeStyler Version: 2.96F
Re: DMX400 Fixture
Post by DMX DAVE »
I don't mean to interrupt this thread but i am also having a problem with DMX400.
Using a AMDJ DMX Dimmer pack (4ch) all works great when just dimming but when using static or sound chase it does not work. What should I try to get it to work?
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: DMX400 Fixture
Post by matt »
Go to the Fixturer Downloads, and download the PIN SPOT fixture, Then add it 4 times for your 4 channel dimmer pack. Now use DMX400
Matt Hankosky
flickr.com/photos/mattxhank
DMX DAVE
Re: DMX400 Fixture
Post by DMX DAVE »
Matt, Thanks! I did get it to work but it only will work for fixtures 2-4 and totally skips channel 1. I tried several different configs and no luck. I had it working perfectly a few years ago. Hmmmmm? What now?
DMX DAVE
Re: DMX400 Fixture
Post by DMX DAVE »
Matt, Never mind. I figured it out. In the fixture list, when adding fixtures drop down 1 line then start adding fixtures.
