StageApe aka cheaplights.com
ultanium
Just started using FS
FreeStyler Version: 4.1.3b
Post by ultanium »
I live near Houston & buy a bunch of lights from http://www.cheaplights.com that are branded as StageApe. Here are a few of the files I created for my lights, will an admin please create a group for them? Thanks
Tom
Jaguar.pff
(44.33 KiB) Downloaded 42 times
FabFour (Mode4).pff
(9.43 KiB) Downloaded 41 times
Eagle (13ch).pff
(48.95 KiB) Downloaded 38 times
Crossfire.pff
(3.43 KiB) Downloaded 35 times
Cobra.pff
(4.5 KiB) Downloaded 36 times
ultanium
Re: StageApe aka cheaplights.com
Post by ultanium »
And here is another one.
Tom
Traffix.pff
(4.03 KiB) Downloaded 31 times
ultanium
Post by ultanium »
And another one. After some research, it appears the fixture file will also work for the StageApe Jackson, which is the same bar as the Stairville Tri-LED. This file is for Mode-6 only. Please note that I tried to add the solid color modes listed in the manual, to the gobo section, but they did not work. I had to manually add the solid colors to the macros instead. Weird...
Tom
FabFour (Mode6).pff
(28.28 KiB) Downloaded 38 times
ultanium
Post by ultanium »
Forgot to mention that all of these fixture files are for v3.4 and higher. Enjoy!
Little late but done!
Cheffrey
Post by Cheffrey »
Do you have the Spider Derby?
gregort
Post by gregort »
How about APE-PHOENIX? Thanks.
mortiz888
Post by mortiz888 »
Does anyone have a profile for the "Astro" or "Psycho" fixtures from Stage Ape, aka Cheaplights? Thanks.
ultanium
Post by ultanium »
I have not created any new StageApe profiles, but I will look at the ones requested when I get a little time. djsupport, thanks for creating the StageApe section, should I repost the files above in there, or can this thread be moved??
Tom
I Thought about moving it but for the benefit of search I'd suggest you create a topic for each light in the new section then people can find them easier :)
gregort
Re: StageApe aka cheaplights.com - Aloha
Post by gregort »
Any profiles for 115-ALOHA (9channel) around here?
Thanks,
Greg
ultanium
Post by ultanium »
Well gang, I am back after 10 years, and will be working on some new profiles for the Fxpar9 (23ch) and these new 230/280 watt "beam" moving heads from eBay (16ch). I do not have any Stage Ape fixtures, at this time.
Tom
Return to “Generic”
