the Fixture groups button goes here : http://www.freestylersupport.com/wiki/fixture_groups
yet there is a http://www.freestylersupport.com/wiki/f ... ups_create
do you think we should merge them? if someone has the time to compare both pages and merge them that would be great and update the link on the button...
Fixture groups issue...
- djSupport
- Spirit
- FreeStyler Version: 3.5.9
Re: Fixture groups issue...
Hello, Djsupport
Both page's are saying the same only:
explains it a little bit better.
but the only way to go to http://www.freestylersupport.com/wiki/fixture_groups page is by opening the
http://www.freestylersupport.com/wiki/f ... ups_create page
/Spirit
/Spirit
- FreeStyler Version: Beta
Hej folks
Sorry for being offline for some time.
I did not want to delete / make a total rewrite of the original page so I made a new and moved the acess to the old one so it only can be found from the new page.
This means that you will get the new page if you want to read about this topic.
And it also means that if someone has linked to original (old) page, could be from forum, then the page is still there in its original form.
If it has only been minor changes then a merge is ok but I think this a total new page so therefore no merge form my side.
- djSupport
remove the old one then as long as theres no information in that one that's missing the new one, its just so it stops confusion,
Hej djSupport.
Think you are the only one that can delete a page
- djSupport
Remove all text deletes page there is no 1 click delete you have to just remove text I can't do at moment as I'm at work
