dmx 400 inverted Topic is solved
soldstatic
dmx 400 inverted
Post by soldstatic »
I'm having a problem with my dmx 400 chaser thing. The colored boxes at the top look like they are working, but for some reason it is doing the inverse of what it shows.
I thought this might be a problem with the fixture so i went in to edit it. I swapped the intensity min/max values. I have 4 RGB led's and two moving head fixtures. No matter what i change on the RGB leds nothing changes when i start dmx400 again. I've got the master intensity all the way up, and the BG intensity all the way down.
When I click the main freestyler blackout button bam everything goes to black just fine. But the DMX 400 is doing something funky i can't figure otu. Please help!
