Chauvet Mayhem Topic is solved
ezazdj
Chauvet Mayhem
Post by ezazdj »
Hi Everyone,
This is my first post, and I just plugged in my Vellaman DMX controller and trying to figure out what in the world I am doing! :shock:
I'm looking for a fixture profile for the Chauvet Mayhem. The manual can be found here:
http://www.chauvetlighting.com/products ... v01_UM.pdf
Thanks!
DaveHoyt
sargentscrufy
Re: Chauvet Mayhem
Post by sargentscrufy »
I also have this light and would like to see a fixture created for it. I am going to try to make a fixture for it, but I have not had much success in the past. If I have any luck, I will try and share my results.
Re: Chauvet Mayhem
Post by Jan_K »
Hej
It is not that difficult to make a fixture for that device.
One way cloud be
The Macro on the Macro tab.
Strobe on the strobe channel.
Speed maybe on Gobo wheel 3
Colos on color wheel 1 and 2.
Color wheel 1 = channel 4
Color wheel 2 = channel 5
Motor Control on Gobo wheel.
Gobo wheel 1 = Channel 6
Gobo Whee 2 = Channel 7
Then you just have to pick the number of colors / gobos that you want to use.
And have a look on the wiki. There are all the info you need.
Re: Chauvet Mayhem
Post by Jan_K »
