Hej Folks
I am looking a bit on zones.
Is there a benefit be using zones and is some specialties for zones.
Or is it just a way to place the fixtures in groups on a tab.
Help to Zone
- FreeStyler Version: Beta
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Re: Help to Zone
the zone can be used to categorize the fixtures
I use it if i have some fixtures in the room which is moodlighting, upligghting etc which i dont have to have 100 % control off. I out them in one zone and keep the fixtures i use for the dancefloor and the disco light on the first zone. then i dont select the wrong light accidentally. .
also if you have a lot of fixtures it is a good way to have an overview.
there is no special features you have only when using zones
/LJ_krede.dk
Aalborg, Denmark
Aalborg, Denmark
Re: Help to Zone
Hej Kristian.
I just needed to be sure that I was writing the right thing in wiki and not missing anything.
http://www.freestylersupport.com/wiki/s ... references
Look at Zone.
Look at Zone.
