Which version to use. Topic is solved
specter333
Post by specter333 »
I have a problem with a "hidden layered window" sticking when shutting down Freestyler. Hasn't been any hassle, just have to click "End Program" when shutting down the pc, but I thought I would install the latest version to see if it fixes it.
I went to the index page and it has a link to download version 3.3.2, which is what I had. While reading through the forum to see if this problem had already been discussed I found links referring to more recent versions and looking at the version history page the latest seems to be 3.3.9.
So my question is why is 3.3.2 the one on the index page? Are more recent version not stable? Should I stick with 3.2 or upgrade to 3.9?
I'm running a HP TC1100 tablet with Win XP Tablet edition SP3 and an Enttech Open DMX .
Thanks for any input.
Mavi
Re: Which version to use.
Post by Mavi »
3.3.2 is the last release version, while 3.4 (!) is the last public beta version. You can download the last public beta from the front page of this forum (here: http://www.freestylersupport.com/fsforu ... m.php?f=31 ).
I use the last beta version and everything works fine. If not there will be a bugfix released within a few days normaly.
