Please I need fixture foe this http://www.dlt.dk/files/7378/WEB%20brug ... manual.pdf
Can somebody help me please?
Showtec Versatrack Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: Showtec Versatrack
Hello, and welcom to the freestyler forum.
i will help you.
where can i help you with.
and a little look at the .pdf, which mode do you make a fixture file for?
also upload a .pff file so i can see what you have made.
i will help you.
- FreeStyler Version: Beta
Hej Guys
It's a quit simple fixture.
If I was to do this fixture, I would do the simples one in both modes and when it's ok make the rest and upload them.
It is a verry simple fixtur.
Hej Again
Here is a first try on the fixture.
It is 8 channel Func on mode.
It will not work 100%.
Following need to be found.
Strobe values on / off
Correct Chase values need to be found.
This you have to find by your self.
Post them here then we can discuss them.
