shapes shapes shapes
soldstatic
Just started using FS
Post by soldstatic »
Another question (unrelated to previous ones) about shapes.
If I want to have one spot follow another, so run the same shape only a step behind, is that possible?
Also I was wondering if its possible to program an override button with a pan/tilt invert or something? So for instance if I want multiple heads to run the same shape, but then at some point i want to invert one of them so it does a symmetrical movement but not the same one. Currently I click the fixture and go in and click the invert pan button, then invert tilt. If I could get this in as an override that would be sweet.
Re: shapes shapes shapes
soldstatic wrote:Another question (unrelated to previous ones) about shapes.
yes if you have something like 4 moving heads you can set fixture 1 to 0(360) degrees fixture 2 at 90 degrees fixture 3 at 180 degrees and fixture 4 at 270 degrees.
this will look if the fixtures are 1 step behind
soldstatic wrote: Also I was wondering if its possible to program an override button with a pan/tilt invert or something? So for instance if I want multiple heads to run the same shape, but then at some point i want to invert one of them so it does a symmetrical movement but not the same one. Currently I click the fixture and go in and click the invert pan button, then invert tilt. If I could get this in as an override that would be sweet.
so far not posible
